I was wondering if there is a way to export an inventer solid to AutoCAD Maps? The reason for this is for one of the other designers needs a part i have already drawn in inventor.
Thank you
Mike
Solved by JDMather. Go to Solution.
You haven't stated what version of Inventor?
File>Save Copy as Type *.dwg doesn't work for you?
What about Environments>AEC Exchange>Save as DWG Solids?
The CADWhisperer YouTube Channel
i am using Inventor 2011 RS, i have tryed File>Save Copy as Type but there is no option for *.dwg
You have to go to Environments>AEC Exchange>Save as DWG Solids. Then go into true view and convert the dwg to the earlier file you want it to.
Isn't that what I said?
That is why I asked what version of Inventor.
In 2012 you can save directly.
