Whenever I try to convert the sketch to a dwg file, Inventor starts lagging and eventually crashes. Can you guys help me out?
Solved by pcrawley. Go to Solution.
Not sure what process you have taken, but Save Copy As > AutoCAD DWG worked first time for me (copy attached). To create that as a PDF, I'd just plot it from AutoCAD.
That must have taken a while to draw in Inventor... and there's still 2374 under-constrained items. Depending on what it's for, you could probably have done it with a couple of patterns, then trimmed the corners off and added a border.
I was right clicking the sketch on lefthand side and hitting "export to". Haha thanks for your help, I should have tried that earlier....
I did use a pattern to create the 120 fingers that go horizontally, but I trimmed the corners individually. How would you have done it?
