Inventor Forum
converting a .dwg file to a solid
13 REPLIES 13
Message 1 of 14
gryles
6609 Views, 13 Replies
Hi
Is it possible to convert a .dwg file into a solid model using Inventor 2010?
I have attached a wireframe electric motor in .dwg format.
Cheers
Greg
Inventor 2012
13 REPLIES 13
Message 2 of 14
victor.tolentino
in reply to: gryles
Try to follow the procedure attached.
Victor Tolentino
Message 3 of 14
JDMather
in reply to: gryles
It is not a wire frame - it is 12931 faceted planar surfaces. I think I would use a reference to remodel. About a hours work would result in a much prettier and smaller (file size) model.
The faceted solid model is 10.5 MB. Modeled from scratch would probably be a tenth of that size and look much better (see attached).
Message 4 of 14
JDMather
in reply to: gryles
I would do a quick drawing and then use the dimensions to recreate using Revolved and Extrudes.
Message 5 of 14
gryles
in reply to: gryles
Thank you
Inventor 2012
Message 6 of 14
Mark.Hopkins
in reply to: gryles
Has anyone ever had the problem in inventor, when you open an autocad dwg file, the options button is greyed out and you can't chose or change anything?
Message 7 of 14
pcrawley
in reply to: gryles
Open the DWG in AutoCAD Mechanical - save it as an IGES file - then import the IGES file into Inventor.
(Tends to make stupidly large files - quick sketch and a revolve is a MUCH better suggestion.)
Peter
Message 8 of 14
Mark.Hopkins
in reply to: gryles
Hey thanks Peter,
Initially I had trouble exporting from AutoCAD to iges as it didnt export some of the wireframe. I think it had something to do with surfaces or something (I have very limited autocad 3d moddeling experience so not too sure)
 In autocad I then exploded everything I could, there seemed to be blocks within blocks. And then saved as a STEP file. It created a single solid which is usable in Inventor. (for civil foundations)
The part created is opaque, so im not sure how to get looking like a solid.  Changing the colour didnt help.
So ive almost been sucessfull, and almost there.
Any advantages in using IGES over STEP?
Message 9 of 14
pcrawley
in reply to: Mark.Hopkins
Right-click the surface model in the Inventor browser and remove the tick from "Translucent" - but it's still a surface model.
Really - the time you've spent on it so far would have been much better spent modelling it as a couple of sketches and features!  (Have you had a look at look at the file size?)
Peter
Message 10 of 14
Mark.Hopkins
in reply to: gryles
Not a problem, the ipt file created  is 4mb
The issue is the dwg file is complicated enough to not want to reproduce the work again. The AutoCAD files are supplied by a 3rd party, I would rather import thier data than risk making a mistake reproducing it. I also hate having to do things twice
For myself this is likely to be required more often in the future, so I would rather spend a little time figureing it out now and save time in the future.
Message 11 of 14
pcrawley
Fair call.  Sometimes (Ok - rarely) the IGES import will solidify the incomming model.  On the occasion where it does not, you can attempt a repair in Inventors repair environment - but that can take weeks.  I would work with the imported surface model.  (Actually - Inventor 2013's repair environment is a considerable improvement over previous releases.)
The problem will come later when you create drawings.  Surfaces are slower to draw than solids, and by default, surfaces don't actually appear.  Right click the model in the drawing browesr tree and check "include surfaces".
Hope that helps.
Peter
Message 12 of 14
JDMather
in reply to: pcrawley
I see no reason to fool with the IGES (and IGES can be set to save as solid rather than surface), but as I said - I would not fool with IGES, there is an easier way.
Message 13 of 14
JDMather
Big mistake.
No.
Message 14 of 14
Mark.Hopkins
in reply to: JDMather
The part created will not be modified in inventor, so- a surface model part will be fine for this application.
You mention an easier way? Can you please enlighten me?
