> thats it, brilliant how did you do this as i need to correct
> another model which is to big to post?
Vincent, without any intention of being offensive, the deck is stacked
against you. Inventor is not well suited for the task and the how to's to
get Inventor to get what you need (? what do you need to do with the
models?), if even possible, would take a while to convey. To complicate
matters the originating software / operator combination doesn't seem to be
any more well suited to the task. It's hard to say without knowing intent,
what's driving the design, but those surfaces are ... they look like they
are less than ideal for conveying whatever the intent is.
Don't know what your options are, but I'd hand it off to someone that has
SWX or Pro/E. They will both stitch and shell the posted tube and can
probably do whatever you need to do with it afterward (drawings, additional
operations?). Whether or not you'll be able to use the data, do anything
except look at it, in IV afterward is still very "iffy". (Best possible
solution; get with the designer and get a better model to start with.
There is probably no reason to have 60 surfaces to get that shape, for them
to be as "busy" and lumpy as they are, or to have the curvature
discontinuities they do.)
If you don't get any better offers (Adesk pick up on it?) and you want to
email me the other translation, can wait a day or so, I'll see if I can put
it together and get it translated into IV (if you are using 5.3 this won't
do you any good) or send you a *.stp.
