Inventor Forum
Convert to sheet metal doesn't make all bends
4 REPLIES 4
jsr
1980 Views, 4 Replies
Godmorning.
Iam having trouble with a part that I wont to convert to sheetmetal and make a drawing with bend annotations.
Converting the part goes fine but the flat pattern is only a "semi-flat-pattern" 2 of the 4 bends doesn't unfold.
I have a 8mm plate and the internal radius is 2mm and the external radius is 10mm and the bend angel is 10 degrees sow everything should be fine.
But how to add the last to bends to make my flat pattern unfold correctly?
Kind Regards
Jens
Inventor Professional 2012
Vault Professional 2012
4 REPLIES 4
drlamb
in reply to: jsr
Check your first sketch. The distance between the two 10 degree bends is not exactly 8mm and that is why it won't flatten.
Donald L.
Inventor Product Design Suite 2016
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
16 Gb
AMD Radeon HD7950 3Gb
JDMather
in reply to: jsr
Maybe something like this (see attached).
jsr
in reply to: JDMather
Thanks for the help.
Looking at your part makes me think it is funny how different ways of working in inventor can be.
Do you allways make the complete 2d layout and then add material afterwards?
Normally I would go directly to 3d and then manipulating (adding/removing) material but seems like that in sheet metal the sketched up part works better for this purpose.
Kind Regards
Jens
JDMather
in reply to: jsr
@jsr wrote:
Do you allways ....
I try to always avoid work - do it the easy way.  Sometimes I am more succesful at avoiding work than other times.
