Inventor General Discussion
Active Contributor
harold_kennedy
Message 1 of 5 (849 Views)
convert to a sheet metal part
849 Views, 4 Replies
11-03-2012 03:50 AM
The part posted with this question is made with Inventor 2013.I would prefer to make this part with the Sheet Metal tools .Please how would this be made with sheet metal tools and how do i flatten this piece?
Best Regards
Harold Kennedy
You could simply Convert to Sheet Metal (see attached).  (done in student version - so examine and then delete)
or
you only need three lines 100, 30, 70 that's it - an open profile and use the Contoured Flange tool to create the bracket and then use the Cut just like you did Extrude.
JDMather
Message 2 of 5 (843 Views)
Re: convert to a sheet metal part
11-03-2012 05:24 AM in reply to: harold_kennedy
or
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Contributor
harold_kennedy
Message 3 of 5 (820 Views)
11-04-2012 12:23 AM in reply to: harold_kennedy
Mr J.D Mather
Thanks for guidance
I attached a file using your recommendations
Is this correct
Harold
mrattray
Message 4 of 5 (770 Views)
11-05-2012 04:25 AM in reply to: harold_kennedy
You don't have to model bend radii. If you draw your contour flange profile to sharp corners Inventor will automatically draw bends in based on the bend radius specified in your sheetmetal defaults.
Mike (not Matt) Rattray
JDMather
Message 5 of 5 (764 Views)
11-05-2012 04:39 AM in reply to: harold_kennedy
These parts are not the same.
You used 10mm external bend radius on both bends on first part
and 10mm on one external and on internal bend on second part.
As I initially wrote - you need only three lines in that first sketch - that's it.  Nothing more.
