Use emboss to extrude cut your text in a sketch.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks Niels,
You can try the any to dwg program, I use it to convert pdf's mainly but it has an image version as well. I am not sure you will get a good quality trace but at least you will get it in autocad.
You can also paste the image in autocad and draw your geometry on top, send the image in the back and draw over it (you can adjust the transparency for the image as well).
You can also do this directly in Inventor, just place the image in a sketch and trace it.
Niels van der Veer
The Netherlands
