Inventor Forum
Convert Text/Image to outlines
4 REPLIES 4
CDytebg
4171 Views, 4 Replies
If I wanted to cut out a logo or text from a flat material is there any way in inventor to import a picture or write text then convert edges into lines which can be extruded and cut from the material?
4 REPLIES 4
salariua
in reply to: CDytebg
Use emboss to extrude cut your text in a sketch.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
-niels-
Text can be done like salariua shows in his screenshot, pictures will have to be either traced or made into a dwg/dxf externally and imported into inventor.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
salariua
in reply to: -niels-
Thanks Niels,
You can try the any to dwg program, I use it to convert pdf's mainly but it has an image version as well. I am not sure you will get a good quality trace but at least you will get it in autocad.
You can also paste the image in autocad and draw your geometry on top, send the image in the back and draw over it (you can adjust the transparency for the image as well).
Adrian S.
blog.ads-sol.com
-niels-
in reply to: salariua
You can also do this directly in Inventor, just place the image in a sketch and trace it.
Niels van der Veer
The Netherlands
