a friend send me a File but it is imposible to open it.
could somebody convert this to .dwg ?
Greetings
Lukas
Solved by wimann. Go to Solution.
Right click on the filename.
Select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Is this all you're trying to do?
Oh, i think it is more..
tanks !!
(do you have some tools to convert Sketchup Models (.skp) to .dwg Files? so I could do this on my own 😉 )
All I did was start up autocad and go to Insert>Import>External File>IGES File...
Autocad probably has the ability to import those as well but I cannot say I've ever tried.
How to convert .igs file to .dwg.
i was not able to do with any of the above solutions
Zip and attach the file here.
Thanks. It was not working because i was working on MAC. i switched to windows. It works fine now. Thank you.
Hello all, I am trying to open an IGS file, but AutoCAD won't open it. Could you teach me how to convert it to DWG? Thanks!
Hi! This IGES file was exported from Catia. It seems to contain a solid body or surfaces. I can import it to Inventor 2022 as a solid body without a problem. Then export it to an AutoCAD dwg file.
What was the error you saw in AutoCAD? It should work.
Many thanks!
In AutoCAD run the IGESImport command.
