James: I also have an igs file which I need converted to dwg format. The file is posted herein. Could you help me out by using Inventor to convert the file to dwg like you did for "horopallo"? The file is 5.844M, which is too large for the 5.24M max to Post with this Message. So if you could send me an E-Mail address or direct me to a file swap/transfer site, I could transmit it to you that way. If you could help me out, I would really appreciate it...Thanks alot! gwsanford1
You have replied to a thread that is 6.5 years old.
AutoCAD will import IGES directly now.
What version of AutoCAD are you using?
@Anonymous wrote:
LT 2008....I don't think my version will do it, but how does the latest version do the conversion? Thanks...
If you read response #10 in this thread - that is kind of important information. You should include relevant information like this when asking someone to do work for you. You are right - I don't think LT has the translators.
In the full version start a new file from appriate units template (inches or mm) and then click on the Insert tab and then click Import and set to Files of Type *.igs
You can download a free 30-day trial of Inventor, AutoCAD or Fusion 360 to do the conversion. (I haven't checked Fusion 360 IGES import - dwg export, but if it does the translation - it can be rented for $25/mth if you have a continuing need.)
I do not see any files? What problem are you having converting your files (other than zipping and attaching them here)?
Dear James Lovell,
Can you please convert these IGS files to DWG formay for me?
It is IGS format only, I've changes the extension to dwg, as it was not uploading in IGS format
Thanks in advance
Sharad Mahale
