Hey everybody,
here is the problem we are facing.
From all our parts of an assembly we made 1 IDW with multiple sheets. Now we want to convert this IDW to PDF's and in such a way that we have one PDF for each sheet, and each PDF files needs the same name as the sheet.
Berry
Solved by Curtis_Waguespack. Go to Solution.
http://www.bullzip.com/products/pdf/info.php
Print one page at a time and name them whatever.
Or try this as well
Hi berry.lejeune,
You can use an iLogic rule to do this:
http://inventortrenches.blogspot.com/2011/07/ilogic-to-save-pdf-files-to-new.html
Here is the code snippet from the 2nd variation found at that link. You can configure the output folder location and the file name as needed. Post back with an example of each and I can modify the code for you.
If you've never created an iLogic rule you can follow this link to see how to create an external iLogic rule. Once created you can paste in the code below for testing.
http://autodeskmfg.typepad.com/blog/2012/01/working-with-external-ilogic-rules.html
I hope this helps.
Curtis
oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Define the drawing Dim oDrawing As DrawingDocument oDrawing = ThisDoc.Document Dim oSheet As Sheet Dim lPos As Long Dim rPos As Long Dim sLen As Long Dim sSheetName As String Dim iSheetNumber As Integer 'step through each drawing sheet For Each oSheet In oDrawing.Sheets 'find the seperator in the sheet name:number lPos = InStr(oSheet.Name, ":") 'find the number of characters in the sheet name sLen = Len(oSheet.Name) 'find the sheet name sSheetName = Left(oSheet.Name, lPos -1) 'find the sheet number sSheetNumber = Right(oSheet.Name, sLen -lPos) 'set PDF Options If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange oOptions.Value("Custom_Begin_Sheet") = sSheetNumber oOptions.Value("Custom_End_Sheet") = sSheetNumber End If 'get PDF target folder path oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFileName & " " & sSheetName & " " & sSheetNumber & ".pdf" 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Next
well, just try kvisoft PDF splitter or try the XFlip PDF page flip software at http://www.xflip.com/, good luck!
