Hello all,
I usually work with blender and I have a problem with a file I downloaded. It is a parasolid file (x_t) which I can't open in Blender. I can't use CADexchanger as well because I am using a MAC. Is there anyone who could help me convert the file into a STL/OBJ/3DS file that I can import in Blender? Help would be greatly appreciated. I compressed the file and it is 5.8 MB so I can't attach it here and would have to send it manually.
Solved by JDMather. Go to Solution.
You could sign up for Autodesk Fusion 360 (runs on Mac) to do the conversion yourself.
