Inventor Forum
Convert 2D drawings to JPG or any picture file
5 REPLIES 5
4322 Views, 5 Replies
How can I convert my 2D drawing from Inventor to an image file?
5 REPLIES 5
blair
Either use the File>Export>PDF or Cad Format and select the type of file format.
Delta Tau Chi ΔΤΧ
in reply to: blair
Yes, tried this, but is there any tip on how i could increase its image quality and have it cropped?
blair
You could use the Windows Snipping Tool. This will allow you to crop but you are limited to screen resolution. If you have a PDF printer on your system, you can Print to PDF and have all the Windows Print Options of Current View and such
Delta Tau Chi ΔΤΧ
in reply to: blair
Well that helped. Thanks!
File>Save Copy As> Select image format > Select x,y value for pixels.
