Hi
I am trying to get the Multi sheet print manager to print out drawings in a particular order. I have 220 drawings for our little waste collection vehicle and I would like to be able to print out the drawings in the correct manufacturing process as I print these to a PDF printer which just puts them in what can only be called computer generated random order.
I have tried to arrange the sheets in the order I want when I select them and copy across to the print window. This still does not work.
In fact it seems to print sheets from the same sheet set how it pleases.
Would appreciate some assistance on this.
Solved by VinodBalasubramanian. Go to Solution.
Is this just to get them in pdf format or do you actually need more than one drawing on each page for plotting or whatever you'll do next?
I am using PDF Creator so then I can batch plot to my virtual pdf printer. The program has the option to "Wait Collect" so that it gets all pages instead of asking where to print each page. You can print them each to separate page or merge them (you can even add Watermark if needed).
You can then use something like PDF Split Merge to split them or organize them.
I guess you wan them sort by the part number which comes as default in windows and with drag-drop to PDF Split-Merge you should get the right result.
You could try using the batch plotting option in task scheduler and then arrange your drawings in a sequence of your needs. It will plot them in that order.
Hope it helps.
Thanks for that suggestion.
I tried it but now I have to figure out where to set the printer settings, as the drawings all printed out at full size which didn't fit on the paper size.
I was fortunate that I was only playing with PDF printer, and not wasting massive amounts of paper.
Any idea on how to make the printer settings suitable using task scheduler?
You may want to try the attached workflow. It should help you to define your printer and in the printer settings, you may be able to define the paper sizes that you want as default to print.
Hope that helps.
