I have an helical screw located in a half-drum.
The half-drum is grounded and the screw is constrained axis to axis to it. I can rotate the screw WRT the half-drum.
I want to be able to do so in a controlled manner, i.e. to be able to call for a rotation of, say, 35 degrees.
I am using Inventor 2015. Can I control rotation like that?
Solved by JDMather. Go to Solution.
Drive Constraint of an Angle Constraint
or
if you have Inventor Professional
use the Input Grapher in Dynamic Simulation.
The CADWhisperer YouTube Channel
