Inventor 2013.
I want to make a contour roll and use the developed length option. How do I accomplish this.
The only way I can get this option to be available (not greyed out) is to have a closed loop sketch, if I have only a single line line sketch this option is not available.
Thnaks,
Can you include a screenshot or he part file or an example of the part file?
I ran into an issue like this and my problem was, my sketch had a radius that was smaller that my sheet metal rule bend radius.
The attached part file has two sketches.
The first is just a line that when using the contour roll does not give the option of using developed length.
The second is a line with a short leg on it and will allow using contour roll and the developed length option.
I ran across this about a year ago when we started playing with the idea of using inventor and after reading your reply remembered that I had to use the second sketch and shave what I did not need off.
