I'm having no problems creating the contour roll, but it won't let me add flanges to the outside edges. I have attached a file that shows the measurements that I want. I need to be able to create a flat pattern. The material thickness is .1046" and 3" deep.
Solved by JDMather. Go to Solution.
Don't use Contoured Roll - Use Contoured Flange.
All you need is the two lines and one arc - nothing else.
Attach your ipt file here if you can't figure it out.
