Can't contour flange a profile in sheet metal which is basicly a quater of a circle with a series of pre bends on one end.
Had problems creating the sketch as could not trim between two construction lines. I could not use the arc centre point tool either.
Had to revert back to 2013 to create my part
Attach the *.ipt file here.
Have you installed Service Pack 1?
Have you installed Update 2 for SP1?
Sounds like you might need to do a Repair Install.
