Inventor Forum
Contour flange isn't created
7 REPLIES 7
Message 1 of 8
Karol-Or
748 Views, 7 Replies
I made this sheet metal part, selected the arc sketch and the perpendicular edge like in the picture, but the contour flange isn't created
7 REPLIES 7
Message 2 of 8
mrattray
in reply to: Karol-Or
I'm not sure exactly what you're expecting there.
How do you plan to manufacture this?
Do you expect the new face to be bent from the arc edge or the straight edge?
Mike (not Matt) Rattray
Message 3 of 8
Karol-Or
in reply to: mrattray
It is to be bent from the vertical straight edge.
It is to continue from the vertical straight edge and bend along the radius at the bottom.
Message 4 of 8
yannicknielsen
Check where I have placed the sketch - That's a way to do it
Product Design Suite Ultimate 2021
Message 5 of 8
Karol-Or
in reply to: yannicknielsen
I can't open it, i have 2013
Message 6 of 8
yannicknielsen
Didn't think about that.
First of all, I created a sketch on top of the flange. Then I use project geometry on the corner, and made sure that the projected geometry from the round corner and the flange was connected properly. Then I used contour flange, and it worked.
Message 7 of 8
Karol-Or
I succeded but the problem was that the sketch had a sharp edge. probably only smooth curves are allowed
Message 8 of 8
mrattray
Are you going to step brake it?
As a fabricator (not knowing the design intent or your shops capabilities), I would recommend making it a separate part, rolling it, and then welding it to the other press braked part.
