I have a part which fails to produce a contour flange. The sketch consists of an arc connected to a spline. Both the arc and the spline as individual elements produce a perfect contour flange but when I join them the coutour flange operation fails.
Sheet Metal: Contour Flange Creation failed.
Outer Strap.ipt: Errors occurred during update
The attempted operation did not produce a meaningful result. Try with different inputs.
Try decreasing bend radius
Feature Compute failed.
Could somebody please help with this. I am trying to model a wrist cuff.
I am using Inventor 2014.
Regards
Victor Pringle
Solved by LT.Rusty. Go to Solution.
Spline not tangent to arc.
The problem has to do with the way the spline interacted with the circle. Inventor wanted to make that a bend. Take a look at the modifications I made to your sketch. First, I made the start of the spline tangent to the circle. Then I opened up the profile of the spline a bit to move it away from the circle, to prevent any overlaps, which would also cause some errors.
Rusty
Just remember: Inventor can't interpret your design intent. When you have non-tangent edges in a profile intended for a contour flange, Inventor will apply a fillet to those profile corners to create the bend. So far as I know - and I could be wrong, I haven't tested this exhaustively - you can't fillet the end of a spline.
Rusty
