I'm working on Inventor 2012 and tryed 2014 comercial licence, but noticed that the content library has less parts then 2012. I tryed to copy from 2012 to 2014 but then nothing shows in 2014 content library. Is there any way to copy content libray from 2012 to 2014? Or does exist better and bigger content library for 2014?
Tnx
Hi!
This isn't true.
The database of Content Center is the same for both versions.
Run the installer again and configure the Content Libraries, maybe you doesnt select all of them when installing inventor.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
