Inventor Forum
CONTENT LIBRARY
4 REPLIES 4
494 Views, 4 Replies
CONTENT LIBRARY
I'm working on Inventor 2012 and tryed 2014 comercial licence, but noticed that the content library has less parts then 2012. I tryed to copy from 2012 to 2014 but then nothing shows in 2014 content library. Is there any way to copy content libray from 2012 to 2014? Or does exist better and bigger content library for 2014?
Tnx
4 REPLIES 4
CCarreiras
Hi!
This isn't true.
The database of Content Center is the same for both versions.
Run the installer again and configure the Content Libraries, maybe you doesnt select all of them when installing inventor.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
blair
in reply to: CCarreiras
Or check your Filters and settings in the Projects file. Open Projects Editor within Inventor, it's the small icon lower RH corner and see if you have selected the CC libraries.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
I know that re-installing is going to solve the problem, but its kind of
wasting time, and I dont have it 😞
Let The Force Be With You!!!!
blair
You only need to install the CC libraries, should take no more than 10 min.
Delta Tau Chi ΔΤΧ
