Sounds like that might be the right solution (hopefully!). I'll give it a
go when I get home tonight. Thanks Sean!
Mark
"Sean Dotson" wrote in message
news:AB959811755A5C8D587B10CF6AF4EC2E@in.WebX.maYIadrTaRb...
> Might try uninstalling 5.3 and then deleting the Inventor registry keys.
> HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor\RegistryVersion5.2
> HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion5.2
> Sean Dotson, PE
> http://www.sdotson.com
> remove all #s from email
> "Mark T." wrote in message
> news:28D3F5872D520D2B4ED1B58D6DCE186F@in.WebX.maYIadrTaRb...
> > Content library is not appearing in the Add/Remove dialog. It may not
> have
> > been uninstalled properly previously, but I don't see it listed anywhere
> in
> > my system during a "find". Could it still be somewhere in the registry?
> > Mark
> > "Kent Keller" wrote in message
> > news:0DC548AC902F230C3A9593D3BBC97F7D@in.WebX.maYIadrTaRb...
> > > Sounds kind of like how R6 acts when the R5.3 library is installed.
Go
> > to
> > > the Add/Remove programs dialog and see if you maybe never uninstalled
> the
> > > Content library from the last time you had it on this machine.
> > > Kent Keller
> > > Member of the Autodesk Discussion Forum Moderator Program
> > > http://www.MyMcad.com/KWiK/Mcad.htm
> > > news:EC27D169EB016556CBFA0834BBD6BBDB@in.WebX.maYIadrTaRb...
> > > > Just installed IV5.3 on my home computer (along with SP1 & 2).
Trying
> > to
> > > > install the Content Library - Windows Installer window pops up
saying
> > "The
> > > > feature you are trying to use is on a CD-ROM or other removable disk
> > that
> > > is
> > > > not available. Insert the 'Redspark Standard Parts' disk and click
> OK.
> > > > There is a "Use Feature From" dropdown window that has only one
choice
> > > > ([Product Name] Label). The browse button does not work.
> > > > If I click OK, another Windows Installer window pops up with the
> yellow
> > > > triangle-exclamation point symbol saying "The path cannot be found.
> > > Verify
> > > > that you have access to this location and try again .... blah, blah,
> > blah.
> > > > I've run IV5.3 on this machine before (Windows 98 unfortunately) and
> had
> > > no
> > > > trouble installing the content library.
> > > > Any ideas?
> > > > Thanks!
> > > > Mark
