I was just kidding as IV uses internal units of cm, rad and grams for
everything...You run into it a lot when doing programming as it converts all
values to one of these units then you have to convert them back.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"A.Fickes"
wrote in message
news:BD5DE9AF4161927D24E7CC25036A9A40@in.WebX.maYIadrTaRb...
> OK, OK Sean... I'll be politically correct (if there is a political
stance
> on this)
> They are SI (International System of Units), not USCS (U.S. Customary
> System).
> Either way I don't think changing the SI to USCS in the content library is
> possible.
> -af
> "Sean Dotson" wrote in message
> news:4A6CF7BC5D6545094F21BFF3EE84748F@in.WebX.maYIadrTaRb...
> > actually it's "cm" based...
> > Sean Dotson, PE
> > "A.Fickes" wrote in message
> > news:441117C9FB114C4229965BF4F8CAA3C1@in.WebX.maYIadrTaRb...
> > > I've been looking for the same solution, but I think since IV is "mm"
> > based
> > > in its programming, it cannot be changed.
> > > "Pat Rogers" wrote in message
> > > news:92BD9FA38E3C59286F70534D7A1E412A@in.WebX.maYIadrTaRb...
> > > > Can anyone tell me how I can control the default units of steel
shapes
> > > > placed from the content library? I have tried changing the units of
> the
> > > > catalog and standard templates and neither seem to have an effect on
> the
> > > > parts. I need the units to be inches and they're always created
with
> > > mm's.
> > > > I know that I can change the in the document settings after they are
> > > created
> > > > but this is becoming tedious. I really would appreciate any help I
> can
> > > get.
> > > > P Rogers
> > > > Smithco-Engineering
