When using Content Centre, in the Favourite’s section, the Tree View will not default to Thumbnail View. Every time I close the Content Centre it reverts back to Tree View.
Any ideas on a solution?
(See attached screen shot)
All the Content Center settings file is located at C:\Users\<current user>\AppData\Local\Autodesk\Inventor 2012\Content Center\Settings.
You could find search result, favorites, history and etc.
But there is a limitation to let the thumbnail view as default viewing.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Will this ever be fixed?
Hi! This is an old thread. I am sorry I am a bit lost here. Do you mind starting a new thread with the behavior you are seeing? Or, add some snapshots describing the behavior.
Many thanks!
Hello Johnson,
it's about to pin the preference view on Content Center Favorites (see images attached). We have two options for the icons view : Tree View and Thumbnail View.
If we set the Thumbnail View (large icons -> easy to understand and select) when call again the Place from Content Center the view for the Favorites is set back to default Tree View.
Our requirement is to pin the preference view on Content Center Favorites once set and maintain it.
With many thanks,
Lucian Crisan
Autodesk Inventor Professional 2018
Vault Professional 2018
you are right, Favorites defaults to Tree View every time when Content Center is open. Thank you for the tip of possible future improvement.
Regards
Jan Priban
