How do I know whether or nt my Content Center is set up as read / write?
Go to your projects, hit the button in the lower right. (see image.)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
If you about having the ability to edit the family table or publish to the content center, I believe it is under the tools tab you will find the publish to CC and edit the CC buttons. If it allows you in then you have read/write privileges.
Do you have Vault? If so are you an admin to that? If so then chances are you have read/write to the CC.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
