The log file you posted doesn't really indicate any sort of problem. A
few things to look at:
1) When you run Content Center Library Manager, in Inventor tools
program group, what do you see? If you see 3 libraries, you're in pretty
good shape. If not, there is a fundamental problem to be investigated.
2) Open the library configuration dialog from the project editor or from
content center -- what's there? If no libraries are configured, you
won't see any content.
Jeff
Svein wrote:
> Hi
> We have a customer that after install of IV 10 can`t find anything in the ContentCenter, it`s empty!
> We have seen this several times before and have then uninstalled everything, cleaned folder and registry, etc.... and most of the time it have worked.
> But when we search the NG we can see there have been several issues about this, so my question is: is there any easy or safe way to fix this problem without spend a lot of time uninstalling......
> I have attaced the CC log file fo
> r the last issue that we have to fix this morning! (2h after this posting)
> regards Svein
