When placiing a bolt from Content Center into an assembly we get the following message:
unable to successfully update the member part file. Problem occurred when setting thread data.
The bolt is then brought in, but the thread defaults to some metric fine thread even though we specify an ANSI coarse thread. The part seems to be sized correctly, just the thread data is wrong.
Inventor Series 2010 SP3
I have the same problem as you after I installed new versjon of office 2007 "Excel"
Try this steps for regedit.
http://forums.autodesk.com/autodesk/attachments/autodesk/78/359802/1/excel.pdf
This solution is posted earlyer.
Jon Olav
i have tried everything.. everything.. but nothing worked..until finally i found the perfect solution...simply just create a new windows user account ..log in the new user account and run inventor...it is working perfect now...
