Inventor Forum
Content Center - Studs
8 REPLIES 8
Message 1 of 9
gaila
2509 Views, 8 Replies
I can't seem to find studs in the Content Center to drop into my assembly. Are they not included?
I'm running Inventor Professional 2014.
8 REPLIES 8
Message 2 of 9
cbenner
in reply to: gaila
No studs are included in CC.  I've been wishing for them for several years... finally created a bunch of my own.  You can AutoDrop them, but they do not work well with Bolted Connection wizard.
I've been playing with that, however, and if I come up with a happy workaround I'll post something or add it to my blog site.... or both!  😄
Message 3 of 9
Cadmanto
in reply to: gaila
I know in 2012 they are there.
Not sure what standard you are looking for, but they are here.
I know these did not work for us and we ended up creating our own with english units at the lengths we tylically buy and publishing those into the CC.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-
happy:
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 9
BLHDrafting
in reply to: gaila
Studs are also in the CC in 2013. I don't have 2014 so I can't test but you may need to play around with your Library View and/or Filter settings to see them.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Message 5 of 9
cbenner
in reply to: BLHDrafting
Message 6 of 9
gaila
Brendan,
Thank you for that screen shot!
I found only about 8 metric studs in my folder. Does anyone know if that's the extent of that folder for 2014? I don't have any filters turned on so I'm assuming that's all my library has.
Message 7 of 9
BLHDrafting
in reply to: gaila
In 2013 it appears that ALL of the studs shown in my earlier graphic are metric. I'm thinking that you don't have enough libraries installed as cbenner didn't as he only had the ANSI library. Below is a picture of the libraries I installed. I don't use any of the ones past the first read/write, but I have all the others there incase I need to copy from a read only to my read.write.
Brendan Henderson
Message 8 of 9
Cadmanto
Like I stated earilier, we created our own and published those.  They have the correct material and physical size specs we need.  It took a little bit of time, but they work like a charm!!! Smiley Happy
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
Message 9 of 9
keith_guillot
in reply to: gaila
How can find studs in Plant 3D Spec Editor?
