Inventor General Discussion
Distinguished Contributor
lama
Message 1 of 4 (233 Views)
Accepted Solution
Content Center - Selecting Components from the Proper Custom Library
233 Views, 3 Replies
06-28-2012 07:12 AM
Because my company is setup such that it has 3 companies operating under one roof and multiple MRP systems we have components that could have different part numbers depending on which company is in posession of it.  As a design Engineer I need to be able to produce production drawings for all 3 divisions and provide production personnel the appropriate part #s for the items depending on where in the process the item is.
The Eng. Dept. acts across all companies the designs are controlled in a single place.  I have created Custom Content Center Libraries for the different companies for standard items like nuts, bolts, etc...
How can I choose which Custom Conent Center Library my parts come from?
Larry Marshall
2013 Product Design Suite Ultimate
Windows 7 Sp1
Intel(R) Core (TM) i5-2400 @ 2.00GHz
6.00 GB of RAM
AMD Radeon HD 6570
Hi Larry,
Not sure I’ve understood correctly your need.
By the way, in the Content Center Editor, you can select one of the custom families you have created and make a Save Copy As.
In the following dialog, you can decide if you want to make an independent or linked copy and apply the Family Name and Description you like to the copied family.
And, in the same dialog, if you click on Review, you will get another dialog where you can define the desired File Name and Part Number.
I hope this can be helpful.
Kind regards,
Alessandro
lama
Message 2 of 4 (228 Views)
Re: Content Center - Selecting Components from the Proper Custom Library
06-28-2012 07:35 AM in reply to: lama
Never Mind.
For anyone else who is brain dead and may have this issue in the future, I simply gave the part Families different names.  Before, I was using the same name for the part family regardless of which company it belonged to.
Larry Marshall
Windows 7 Sp1
6.00 GB of RAM
AMD Radeon HD 6570
lama
Message 3 of 4 (210 Views)
06-28-2012 11:01 AM in reply to: lama
Seems that I jumped the gun a little, renaming didn't make Copies of the same family with different part number data available simultaneously, only the latest one to be changed/saved.
Larry Marshall
Windows 7 Sp1
6.00 GB of RAM
AMD Radeon HD 6570
Product Support
alessandro.gasso
Message 4 of 4 (198 Views)
06-29-2012 03:33 AM in reply to: lama
Hi Larry,
Kind regards,
Alessandro
Alessandro Gasso
Product Support Technical Lead
MFG - Inventor
Autodesk, Inc.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
