Hi
Software ref: Inventor 2013 64bit SP1.1 - Vault Professional (client/server) 2013 update 1 - SQL server 2008 R2
Our office has recently been lacking a Content Center due to the error described below...
- Users can click "place from CC" and navigate to the part they require
- On selecting the part the following error shows up:
- There is no option to add anything afterwards. This has also crocked our frame generator....
- This happens with both our custom library and standard libraries.
I've had a look at the ADMS console where the libraries appear to be fine, and the SQL management studio, where nothing is showing up an error...
So far all we've managed to try is restarting the server, which hasn't worked. I was hoping someone might have some experience or thoughts on the error!
Here's how it appears in the server log:
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Content.Services.ContentService.GetFamilyPropertyValues(Guid[] famGuids, Guid[] propGuids, String lang)
at Connectivity.Web.Services.v17.ContentService.GetFamilyPropertyValues(Guid[] famGuids, Guid[] propGuids, String lang)
Exception(Inner): Procedure or function 'GetFamilyPropertyValues_String' expects parameter '@familyGuid', which was not supplied.
Stacktrace(Inner): at Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
at Connectivity.Core.Database.SqlAccess.ExecuteReaderInternal(SqlCommand cmd)
at Connectivity.Core.Database.SqlAccess.ExecuteReader(CommandType commandType, String commandText, SqlParameter[] commandParameters, Int32 commandTimeout)
at Connectivity.Content.DataAccess.dbFamilyUtils_RC.GetFamilyPropertyValues(Guid familyGuid, Guid[] propGuids, String language)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Like I say, any ideas please let me know. Cheers, Jon
This sounds like more of a Vault question than Inventor, but: Do you have any problems accessing the Vault throught Client? Can you open files from Vault, check out and in... is it only the CC that is showing this disconnect?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi Chris
Fair point really - think I should move or replicate this? If I can?
There seem to be absolutely no issues with Vault check-in/out and/or placing files from Vault.. I've had our reseller have a look at it and have no suggestions which have borne fruit so far!
I can have the thread moved to the Vault forum, that way it's not in two places. Let me give that a shot.
Chris Benner
I had a thought,... are your Vault CC libraries added to your Inventor Project?
Chris Benner
They certainly are! No settings have changed from a content centre that's been working fine for years. I get the horrible feeling that it's a very specific glitch, maybe something within SQL settings etc.
I can even open and edit the content centre library tables - but I have noticed that in the "Family Properties" dialogue box there are some changes. Firstly there are only "General" and "Thumbnail" tabs where there would usually be Parameters / Links as well. On the General tab:
- "Family Folder Name" section has disappeared completely.
- "Library" field is blank where it would usually have a library specified.
Seems like some link between the vault and the libraries is damaged?
That seems like a reasonable assumption.
I'm really hoping to get this thread moved, I have requested that it be. It takes some time. I'm hoping there is someone on the Vault side who might have a clue, because this sounds like it's a system error vs a setup problem. I feel your pain!
Chris Benner
Jon,
I think that I would make sure that your have updated your systems.
You state that you are at:
Autodesk Inventor 2013 Service Pack 2
http://usa.autodesk.com/getdoc/id=DL21702054
Update 4 for Inventor 2013 Service Pack 2
http://usa.autodesk.com/getdoc/id=DL22744178
Vault 2013 Service Pack 1
http://usa.autodesk.com/getdoc/id=DL21017345
Update 2 for Vault 2013 Service Pack 1
http://usa.autodesk.com/getdoc/id=DL22156301
This would be a reasonable first step.
