I have a user here that creates and publishes all the client's custom parts and then puts then into the Content Center for global use. Today he's run into a problem when attempting to create a rivet.
The attached is a pdf showing what he's running into. There are two main red flags of interest as you'll see, one being why the "rivet" category is not available although it exists and two, why doesn't the AutoDrop feature work unless this part is stored into a different category such as 'Round Head" bolts?
He hasn't run into this before today and he's created numerous other parts such as washers, spacers, nuts, bolts, etc. Why are the rivets causing issues?
Thanks in advance for you help, I will be sure to pass along any info.
That is interesting, why wouldn't Rivets be a choice?
I created a dummy part and attempted to Author as a rivet and saw the same thing you did. So I authored it as "Other", and then published it as a rivet. During the publish, it warns that the part was authored as Other, and you may lose authoring info if you proceed... yes or no. I said yes, and it SEEMED to publish ok... but I'll admit i didn't have time to play around and test it from the CC.
This is IV 2011 Pro btw.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hmmm......sounds like a bug to me seeing it's happening on both 2011 and 2012.
If I get the chance tonight when I get back to the office, I'm going to attempt this on 2012 ultimate...I doubt it'll be any different, but one never knows.
