I am trying to publish an ipart to the content center but I keep geeting stuck when publishing it.
I author it as a reducing elbow but when I get to map family column I only have one NominalSize. Shouldn't I have two?
When I try the same thing with a tee, I only get one NominalSize
Solved by douthett. Go to Solution.
Did you generate all files before publishing?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
We finally figure out the problem
My compnay decided to create our own version of the content center and our own folder for it. What we didn't know was that the content center fodler had information embedded in them to tell teh content center how many NominalSize each part should have.
The solutions to our problem is to copy the folder to our content center and then load our files into those folder.
