I´m having som problems to publish a part in to the Content Center. It´s the first time I´m doing this.
The part is made with parameters and is a little bit more complex than a bolt.
The problem is that I got this message: "There are external dependencies found in the document. Please remove the dependencies then proceed with this comand."
I need help!
Does the part you created have a link in it to a file such as an Excel spreadsheet? Can you post the file here?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
No final solution was offered here, but you might look at this thread also.
http://forums.autodesk.com/t5/Autodesk-Inventor/Error-publishing-iPart/td-p/2927788
Sadly, Dennis is no longer with us. he was a font of knowledge and help for all of us.
Chris Benner
The solution was to run the "Purge" commando. Probably some link for the colours or the material were troubling here.
That makes sense. Was this part converted from an earlier release of IV? Maybe going form the old colors to the new appearances got something stuck in there.
Chris Benner
