I have a content center part (ANSI ASTM A6/A6M) I place it as custom and set a length. I then put in Iproperties such as Engineer and Project name. When I realize that I have the wrong length. I right click on the part and select change size. After I change the Size the iproperties that I changed are all gone.
Any Ideas would be awesome
Inventor 2010
Unless you are setting those properties in the family table, you are creating occurence iproperties. When you change size, you are actually changing the model, and therefore, the occurence.... so you will need to set the iproperties at that level again.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
