The new release has me baffled. Some of the b16.9 fittings are the wrong color. Is there a way to change them back to the old color?
The reducer and straight tee are oddly still the correct color, but the others are a lighter shade of gray.
When I click on a light gray fitting, the material and apperance say "Steel, Wrought; Steel". When I select the old darker color, it says "Wrought Steel; Metal-Steel."
I'd like to change this at the CC level instead of manually changing them in every assembly and design representation.
Bump.
In content center editor, copy the offending families to a writable library. Open the family table, right click on Material and select Column Properties. Next to where the material is listed is a browse button that allows you to select any of the defined materials.
