Inventor Forum
Content Center My-Library. Why? it is change to READ-ONLY from Read/Write
6 REPLIES 6
WillieArolf
1205 Views, 6 Replies
Hi guys/gals,
I just want to ask query regarding my exisiting Content Center Library "My-Library". Previously the Access was set to "Read-Write".
Now, I was trying edit 1 of the "Stud" that I have edited before. Now, I can not edit it as it was change to Read Only". How do I revert it to previous Access status to "Read-Write".
Thanks & Regards,
Willie
Autodesk Inventor Professional 2019
Windows 7, 64-bit
6 REPLIES 6
blair
in reply to: WillieArolf
All I can think, is that you don't have adequate permissions to access the directory. Very odd indeed.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
WillieArolf
in reply to: blair
I am really surprise as I have been using this library for 3-4 years now... Only last Friday when I want to edit a certain dimension.
Thanks & Regards,
Willie
Windows 7, 64-bit
blair
Try logging in as a different user, preferably with Admin privileges and see if it's normal or still Read-Only.
Delta Tau Chi ΔΤΧ
WillieArolf
in reply to: blair
Actually, I am the Admin of these computer and yes I have the Admin privilege.
Thanks & Regards,
Willie
Windows 7, 64-bit
We've had this problem also and i've found the solution in this topic:
http://forums.autodesk.com/t5/Inventor-General/Change-a-Read-Only-CC-file-to-Read-Write/m-p/3147594/...
Turning off the UAC worked.
WillieArolf
Thank you for sharing this informative solution.
Thanks & Regards,
Willie
Windows 7, 64-bit
