Hi guys/gals,
I just want to ask query regarding my exisiting Content Center Library "My-Library". Previously the Access was set to "Read-Write".
Now, I was trying edit 1 of the "Stud" that I have edited before. Now, I can not edit it as it was change to Read Only". How do I revert it to previous Access status to "Read-Write".
All I can think, is that you don't have adequate permissions to access the directory. Very odd indeed.
Try logging in as a different user, preferably with Admin privileges and see if it's normal or still Read-Only.
We've had this problem also and i've found the solution in this topic:
Turning off the UAC worked.
