Inventor Forum
Content Center Locknuts missing thread info
3 REPLIES 3
Winks87
375 Views, 3 Replies
I insert a locknut from Content Center under the Shaft Parts folder - the inch series locknuts have no threads on the i.d.  If I look in the table, the thread info says: "missing".  Is this normal or is my content center missing info?  Also. why is the internal tab of the lockwasher missing?  Has anyone else seen these?
James Winkler
3 REPLIES 3
mercerc
in reply to: Winks87
Charlie M
Inventor Product Support Specialist
mercerc
Good catch,
There is nothing wrong with your Content Center (CC) it seems the base model used didn't call out the thread size. When I checked on of the models it calls a feature thread but it wasn't set correctly and no thread was called out. That is why in the CC all the thread sizes are missing.
I will inform QA of this. In the meantime you can if you want edit the CC componet after placement (this will require a different project file that calls out the Content Center Files location out as a workspace) and you can add the thread.
Charlie M
Winks87
in reply to: mercerc
Thanks, will do.
James Winkler
