I insert a locknut from Content Center under the Shaft Parts folder - the inch series locknuts have no threads on the i.d. If I look in the table, the thread info says: "missing". Is this normal or is my content center missing info? Also. why is the internal tab of the lockwasher missing? Has anyone else seen these?
Solved by mercerc. Go to Solution.
Good catch,
There is nothing wrong with your Content Center (CC) it seems the base model used didn't call out the thread size. When I checked on of the models it calls a feature thread but it wasn't set correctly and no thread was called out. That is why in the CC all the thread sizes are missing.
I will inform QA of this. In the meantime you can if you want edit the CC componet after placement (this will require a different project file that calls out the Content Center Files location out as a workspace) and you can add the thread.
