Hi to all,
if i have created a custom content center library, where all content center parts use my material "Steel XYZ", is there a way to use it in old assemblies that use a no custom content center library?
I mean, i have 100 assemblies that use bolt with Steel Mild material... can i change that material changing thecontent center library and using mine that use "Steel XYZ"?
Thanks for support!
Solved by cbenner. Go to Solution.
You would need to open each of those assemblies and use Replace From Content Center on the parts. You can do a "Replace All" on each part, but there is (unfortunately) no magic button that will just switch all of your fasteners to the new library. If the fasteners came from a read only library, you may be stuck replacing them all the old fashioned way.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
