Inventor General Discussion
Distinguished Contributor
panzilte
Message 11 of 14 (131 Views)
Re: content center library not updating PLEASE HELP!!!
06-21-2013 08:06 AM in reply to: cbenner
The part number has been fixed.  The issue was getting the files to refresh.  The only way I was able to do that was to delete the old and create new.
cbenner
Message 12 of 14 (128 Views)
06-21-2013 08:17 AM in reply to: panzilte
I'm saying that if the properties were not mapped, they would not refresh.  Just want to make sure that was not the issue originally, because you may get the same results again this time.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Valued Mentor
Lancasterm
Message 13 of 14 (119 Views)
06-21-2013 11:08 AM in reply to: borissljivar30
Not sure this will help since you are using the vault server to manage the content center...   But without Inventor running go to
For XP:  C:\Document and Settings\<user name>\Local Settings\Application Data\Autodesk and rename your Inventor <version> folder to Inventor <version>_OLD...
For Win 7:   C:\Users\lancasterm\AppData\Local\Autodesk and rename your Inventor <version> folder to Inventor <version>_OLD...
Restart Inventor and let it recreate the content center caching files/folder.
Just wondering if your local CC caching files are not being updating (I have seen this before and deleting the CC caching folders fixed the problem)....   So Inventor continues to think the information in your model is up to date even though its not.
Side note:  If you created favorites in your CC this information is also stored under that folder structure...  If you did, you can rename the sub-folder Content Center to Content Center OLD
Valued Mentor
Lancasterm
Message 14 of 14 (115 Views)
06-21-2013 11:24 AM in reply to: borissljivar30
Ok I was going back over the replies and have a couple more questiongs/thoughts... When you do a refresh of standard components are you getting any message? If no, do you have a user created LOD active? Also are the local content center part set to read only on your hard drive? Sometimes that happens when data has been migrated and you have to remove the read only attribute from the file itself. Do you have any (mapped) custom IPROPERTIES in the family table with blank cells. If you do then you need a formula (typed) as &" "& for the given blank to create a space for that IPROPERTIES.
