Inventor Forum
Content Center Library is Missing? Where can I download it?
19 REPLIES 19
Message 1 of 20
Bosey85
11845 Views, 19 Replies
Hello Everyone,
I am currently taking an Inventor class and it requires us to use fasteners and what not in our projects. However my content library is missing, I have double and triple checked the file location. Some how when I installed Inventor 2010, my content center libraries were not installed. I am not talking about autodesk vault, and do not have a server to connect to. I just want the standard content library filled with all the standard fasteners and other content and I have yet to find any help on the autodesk site nor on google. Please help if you can. Thank you in advance.
19 REPLIES 19
Message 2 of 20
in reply to: Bosey85
Run install again and just install desktop content libraies.
Message 3 of 20
Bosey85
Thank you John for your quick response, I will give it a shot.
Message 4 of 20
Bosey85
John, I tried your method and files were downloaded and installed. However, these files seem to be unusable and I am not able to load the fasteners library nor any other library. I will attach the newly installed files to see if you or anyone can make sense of how to use them. All of the files are .idcl files and do not load properly and they are very large. If you can help please that would be great. Thank you.
Message 5 of 20
Check your library configuration in your project file (bottom button on right side of lower window).
Message 6 of 20
Bosey85
John, I cannot find the location of the button you have mentioned. I am a noobie so it might be my fault. I have a standard mm iam opened right now. I have attached a screen shot of my desktop. If you could please tell me where to go that would be great. Thank you very much for your help.
Message 7 of 20
Mange tab Get Started tab > Projects, then look for the Configure Libs button as described earlier
better yet, go to the Get Started tab and click the Tutorials button, and then go to the Level 2 General Interest tab, and choos the Content Center User Libraries tutorial, it covers this and more.
Message 8 of 20
You cannot have files open when you configure a project file.
Message 9 of 20
Bosey85
I tried what you said and to no avail. It will not let me select the edit library button in the project manager. All that is in my content library are .idcl files. What are .idcl files and what are there purpose? Thank you for your help.
Message 10 of 20
Good point to make for general project edits, but you can add/remove CC libs with file open.
Message 11 of 20
Inventor Desktop Content Libraries
These file are your CC database files.
Before you can use the Desktop CC (rather than the vault server) you have to go to Application Options> Content Center tab, and specify to use desktop CC, and point it to the IDCL files.
Message 12 of 20
See attached file, have you seen this?  If so, post screen shot.  If not, that's where you need to go.
Message 13 of 20
Bosey85
There are no options to change or point to the .idcl files, this is what it shows in the attached screen shot.
Message 14 of 20
Bosey85
John, there is no edit styles option in that location. Here is a screen shot of the options that I do have. Thanks.
Message 15 of 20
Looks like the bottom button is greyed out.  I had this problem before, I did a clean uninstall and reinstalled.  Sorry but that is the only way I know to fix it.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13187758&linkID=9242018
Message 16 of 20
Before an uninstall, did you check: Application Options> Content Center tab, and specify to use desktop CC?
Message 17 of 20
Bosey85
Bmiller, Yes I did check that. There is no where to change the libraries to cc or point them to the file folder that I have idcl files located. Thank you for everybody's help. Before I uninstall I am going to go by my school. They have the proper library files. I am going to see if I can just copy them to a flash drive and paste them into my content library directory because they are in the proper file format. Once again thank you for everyone's help.
Message 18 of 20
Good tip.... never tried that... 🙂 Guess I'm automatically ingrained with the need to have all files closed.... 🙂
Message 19 of 20
Unable to install inventor content library in Inventor 2017
Message 20 of 20
SBix26
The log indicates that your download failed, so installation never started.  Instead of using the Install Now method, use Browser Download to first get the install files copied to your computer, then run setup to perform the installation.  This has the bonus of never needing to download the files again, they are right there on your computer for repair, reinstall, add components, etc.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
