Inventor Forum
Content Center Libraries: Parker
2 REPLIES 2
1820 Views, 2 Replies
Is the Parker Content center library only available in Inventor Pro? I see it listed, but in red and says unavailable.
Using Inventor 2011 (standard version)
Paul
2 REPLIES 2
I am assuming you are talking about seeing this info (red/not available)  through the project settings.  If so it sounds like the parker libary (CC) file didn't get installed.
miluse.latalova
The Parker content is available for Inventor standard version. As mentioned, most probably the library was not installed.  For Desktop Content, you need to run Inventor installation and select the Parker library to install. For the Vault Server, you need to run the Vault Server installation to install the Parker library on the Server.
Mila Latalova
