Hello, I just had to deal with the same problem yesterday.
The command line I had to run was the following:
Connectivity.ADMSConsole.exe -OSiteRename -SNOOLDCOMPUTERNAME
-SNNNEWCOMPUTERNAME -DBUsa -DBPSecretPassword
NB:Please beware of the mail program wrapping long lines!
Everything on the line seems to be case sensitive.
Replace OLDCOMPUTERNAME, NEWCOMPUTERNAME and SecretPassword accordingly.
If you don't know the secret password, try AutoDeskVault
If that does not work, you may have to talk to your IT support and have
them reset the MSSQL 2005 sa password for the AutoDeskVault database.
Hope this helps
Regards
Jeppe
davidngandu wrote:
> Good morning,
> There were problems with my computer and our IT support had to rename my computer. Since then I cannot access the content center. The following message appears:
> If server "1468-536" is intended to be a member of the replicated environment please install product stream replicator. If this computer has been recently renamed, please update the site via the server console command line option.
> How do I update via the server command line? Please note that I have never used vault before, I used to just press the content center button and everything worked.
> David told me yesterday to reload the libraries via the disc 1 but as soon as I do this the program hangs (left it running through the night). I stopped it and this is why I contact you now.
> I need to access the bearing database for an urgent project.
> Your urgent attention is appreciated.
