After update some properties in the families in our content center library (in Content center editor) we can't place CC parts anymore?
1. We get a text box who ask if we want to check out the file from Vault.
2. No matter what we click Yes/no another textbox appear who say we dont have write permission?
and no part is inserted in the assembly.
Other part who is in the original CC works fine just our parts dont work?
is it possible to restore earlier version of CC?
Info:
Inventor 2015, SP1 Update 1
Vaul 2015, R2
What to do
BR
Timmy
Solved by Timmy_Stalnacke. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
Timmy
What happens if you perform a refresh standard component in your assembly? Does this person have the proper access within Vault to check out content center components? What is the lifecycle state of this component and is it locked? Please see my article about content center: http://synergiscadblog.com/2014/02/28/working-with-inventor-content-center-part-1-of-3/
Mark L.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thank you Mark!
When i uncheck the "Refresh out-of-date standard parts during placement" box i can place components again.
We went to Inventor 2015 a couple weeks ago and this is the firs time the CC is changed, that probably why the problem came up now!?
Ok this wasn't the solution for us. we had to log in as JobServer and open every part from your Library and check out and check them in again.
This solve the problem for us now but i guess this isn't the right way to go?
Best regards
Now I have this problem again!
It only on my computer, my colleagues don't have this problem so it have to be some of my settings?
I have deleted the local copy of CC.
it works fine when i change to default project but when i change back to Vault project Inventor wants me to check out CC parts again.
its only our company library who this occurs.
Best regards
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
That check box under Content Center was the problem I was having placing components. Fixed it.
THANKS!!!!
Quick follow up, is there any danger to not having that box checked like updated files not updating?
