I trying to use the content center feature in a part on Inventor 2013 but it doesn't work.
It does work on Inventor 2012.
Thank in advance for any help on this issue.
Best regards,
Peter
Go into your 2013 project and make sure Inventor Feature is available in your content center configuration.
Are you at the part level or at the assembly level?
The center cone is a iFeature and the upper cone was placed from CC
Check that the Content Center is being loaded: Tools>Add-In Manager
Works fine with a CONE and CYLINDRE but all the rest doesn't.
Can you please try to make a bloc.
Peter
PS : Content Center is loaded.
works fine here, you do have an existing shape/item on which to place the Feature
I dont get what's wrong with my Inventor????
Can you send me your part file please, so I can try to edit the block feature and see what happens on my Inventor?
Best regards,
Peter
Finaly I tried on my home computer.
Win 7 x64
Intel Core 2 Quad Q8300 - 2.5GHz
4 Gb
Nividia Quadro 2000
Inventor 2013 Ultimate SP1.1
Content Center Features work fine.
On my buissines copmuters : HP Z600 (Win 7x64 French), Z420 (Win 7x64 English) and 8560w (Win 7x64 French) it doesn't work at all. On my collegues HP Z600(Win 7x64) it doens't work neither
It don't know wat happens.
Peter
I'm trying the same problem in my job. We have the Content Center files folder in a network.
(Win 7 64bits Portuguese - Brazil) - Autodesk Inventor Professional 2013 SP1.1 Update 1
Reguards,
Attched part
As pavsec63 said, works fine with a CONE and CYLINDRE but all the rest doesn't.
Not sure what your problems are, works fine with all sorts of differnent CC features
