Simon,
This isn't suppose to work this way. If you don't have the appropriate
permissions to make edits, you should be restricted from getting into the
Content Center editor. Can you tell me what user roles were assigned to
your user account initially, and then what you changed them to? You can
have multiple roles, so it would be helpful if you told me each role
assigned to you.
thanks for reporting this,
-Brent
wrote in message news:5413818@discussion.autodesk.com...
Good Morning all
You might of remembered a while back i was having problems copying library
content to a custom library. I have recently found a solution so I'm
posting it on here, if anyone else is having similar problem.
When trying to copy a family to your custom library, make sure your
permissions in vault manager are set up so that you have the privileges to
do so, because if you don't, inventor will not prompt you with that
information, it will just pretend that it copied it and yet the family will
not be copied. Not sure if that's a glitch on its own or not.
Simon
Message was edited by: Simon Kursa
