Paul,
Welcome to the forum.
What do you mean by duplicating itself? It looks like (based on your image) that you have loaded the CC on your local.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks for the answer.
I had my project path incorrect which I believe was duplicating everything I used out of the c.c. into another folder. Small matter of capitalization in the path. I have tested my theory and I believe that was my problem. I now have my File path in options corrected and I have set my project to go to that default folder.
I am set up as single user with the c.c on our main server. works well in the same building but i have had to thumb drive thru the mail for our remote location. Taking from a shared server takes too long for distant facility. We don't want to use vault too much trouble for three designers. Thanks again.
Now i have to figure out how to remove my post.
No problem. Just glad you figured out your issue.
well... not the answer i thought. still duplicating but now INSIDE the library. does c.c. make a shortcut library or something? It doesn't do any good for me to edit the library if inventor looks at an old library.
And how do I UNsolve my post?
