Hi!
I`ve reinstalled my OS (windows 7 64bit) recently and installed Inventor 2014 en. After this I can`t use Content Center files. After clicking on the "Place from Content Center" button - nothing chappens. I`ve reinstalled the Inventor, installed SP1 - still the same. Does anyone has any idea what is wrong? I`m using Single User Priject, whole Content Center libraries are installed (I`ve checked it).
Before OS reinstallation everything was correct.
Please help 🙂
thanks a lot,
Marcin
Solved by Curtis_Waguespack. Go to Solution.
Marcin,
Welcome to the forum.
For starters go to the tools>addins and see if you have it activated.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Where is your CC loaded? Local or network?
When you ope up yout project file where does it say your CC is pathed to?
Hi amcik,
It could be that the Content Center dialog box is coming up off screen. This often happens when a configuration for dual monitors has changed. To see if this is the issue see this link:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
My CC is loaded local:
C:\ProgramData\Autodesk\Libraries\Content Center\Content Center\Libraries
The same path is used in Project:
Hi Curtis,
I am using a configuration with dual monitors. The problem is, that the CC dialog box does not exists. When I`m trying to press ALT+Space and Move options after turning on the CC button, a I can move.. but whole Inventor window :-(.
thanks for your help,
still looking for some adviceces how to fix the problem,
Marcin
Try going to control panel>add/remove programs and do a repair on the install and see if that does anything.
I`ve done this twice already - nothing happens :-(. Moreover, I`ve reinstalled the whole Inventor yeasterday - still the same problem... 😞
Any idea what is going on?
thanks,
Marcin
Hi amcik,
If you go to the Tools tab > Applciation Options button > Content Center and look at the path for the CC libraries, and then browse to that location, do you see the *.idcl files?
If so, when you click the Configure Content Center button in the project editor, do you see the libraries loaded and avaialble (or whatever the status is called)?
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FCA4F005-8CC1-437B-A673-9EB7AA37F7AA
I hope this helps.
Curtis
I found this thread. See if it speaks to anything you have done or need to do.
http://forums.autodesk.com/t5/Inventor-General/Content-Center-problem/td-p/1399006
Hi Cadmanto,
Just FYI, that thread is from 2005, which would predate the Desktop Content Center. Meaning that at that time the CC Libraries were installed on the ADMS (Vault server). My understanding / assumption is that amcik is working with the Desktop Content Center, therefor none of the SQL related information will apply.
Hi amcik,
Looking back at your screen shots, I'm not sure in your project file looks correct to me. It looks like you have the CC file store path mapped to the CC library path. I would check to see what you have the CC Library path under Application Options (see my last post). It might be possible you have these paths reversed?
So just to review, Content Center basically has two parts to it:
a) Tools tab > Application Options button > File tab > Default Content Center files area.
b) The Project editor > Folder Options > Content Center Files path
b overrides a, if it is set
I hope this helps.
Curtis
The problem is... that when I click on the Configure Content Center Libraries in the Projects dialog box... nothing chappens :-(. The Configure Libraries box does not appear... The same situations as with using CC.....
Marcin
Thanks Curtis, I did not know that. Trully the deeper realms of Inventor I have not reached yet.
You do make a good point about the OP's pathing. Mine in the project file says "Default" where as his says
which looks strange to me. Almost looks modified. Which speaks to what you asked about having them switched between the application options and the project file. I like you question this directory structure between the two in the OP's system.
Mine accepting all of the default locations upon install looks like this.
Amcik,
So you cannot see this dialog window.
Try going to this folder in Windows Explorer and see if there are any libraries loaded.
Hi amcik,
So the only thing that I'm still unsure of is what you have set at Tools tab > Applciation Options button > Content Center tab. Have you double checked to ensure that the Desktop Content option is selected? And not the Vault option?
Past that I'm not sure what the issue would be.
I hope this helps.
Curtis
Here you`ve got my set up:
Project setup:
Tools/Application Options/Content Center setup:
And the content of this directory:
amcik
Hi amcik,
So everything looks good, other than the CC files path in the project editor. As I mentioned in post 13, the path in your project file is not set correctly. It should not be set to the same path as the libraries. I'm not sure if setting it the same would cause the issue you're seeing, but it is one more thing to rule out. I would try setting the Content Center Files path in the Project > Folder Options to some other path, just to see.
Also, you might try setting the tutorial files project active rather than the Default project (we typically never suggest working with the Default project).
I hope this helps.
Curtis
I`ve done what you has suggested:
- I`ve changed the directory in Project > Folder Options,
-I`ve changed the Project to Tutorial Files.
Still the same problem.
Maybe the problem is deeper? I meen: shoudn`t the dialog box of Content Center appear even when the directory with libraries would be empty?
Marcin
(sorry for my English... I hope you understand me correctly).
Hi amcik,
Okay, so I think at this point we can say that it is not an issue with your Content Center setup.
And I think that you are correct in thinking the problem is deeper. Unfortunately, I'm out of suggestions other than to ask if you have installed all of the latest service packs and hotfixes?
http://knowledge.autodesk.com/support/inventor-products/downloads#?rows=10&sort=score
I hope this helps.
Curtis
